I am building a project where I need to know the value of the pitch from the mpu6050. For this I used following equation:
"pitch = atan2f(AX,sqrt(AY*AY + AZ*AZ))* 180/M_PI"
After this I wanted to know what the value was so I used UART to print the value to my serial monitor (used MobaXtrem), but nothing is being printed.
After a bit of testing I found out that the problem is with the math function's themself. This is because I used a simple test program in the form of:(this also didn't work)
float sinus;
sinus = sin(90);
// UART_PUTCHAR(sinus);
printf("the value of sin is: %f", sinus);
And yes I included math.h and added the 'm' in the linker.
Thank for the help
PSoC5 LP MCU
Switten,
The problem you are having is that Creator uses the newlib-nano library by default. This library removes the "float" conversion option in the printf-type functions to save on FLASH. If you need the correct library to handle float values see the following KBA: Printing-floating-point-values-in-PSoC-Creator-KBA231059
Switten,
