how to enable USB_EP2_ISR fun
sugu_293411
how CY7C63813 enable  USB_EP2_ISR,
My USB device is HID,use Endpoint 1 to IN and Endpoint 2 to Out,  bmAttributes is 3(USB_ENDPOINT_TYPE_INTERRUPT)
but when PC send data to cy7c,it can not triger USB_EP2_ISR. thank you for hlep.
export  USB_EP2_ISR
export _USB_EP2_ISR
USB_EP2_ISR:
_USB_EP2_ISR:
   ;@PSoC_UserCode_BODY_EP2@ (Do not change this line.)
   ; Insert your custom code below this banner
   ;   NOTE: interrupt service routines must preserve
   ;   the values of the A and X CPU registers.
STD_EP2:    EQU     1   ; Set this equate to 0 to remove the standard
                        ; endpoint handling code
   ; Insert your custom code above this banner
   ;@PSoC_UserCode_END@ (Do not change this line.)
IF  STD_EP2
    PUSH A
    XOR     [USB_EPDataToggle], 4 ; Update EP2 data toggle
    MOV     A, REG[EP2MODE]            ; Get the mode
    MOV     [USB_EndpointAPIStatus + 2], EVENT_PENDING ; For the API
    POP A
    RETI
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
How do you judge USB_EP2_ISR is triggered or not?
Some documents for your reference:
Device datasheet
https://www.cypress.com/file/139361/download
Interrupt apps note:
https://www.cypress.com/documentation/application-notes/an90833-psoc-1-interrupts
USB user module datasheet
https://www.cypress.com/file/126441/download
Roy Liu
