jobe_4684601
Help. I'm trying to find a setup to program CY8C29866-24AXI 100TQFP chips PRIOR to installation on a board. I have been trying to work with Cypress for an answer but they only seem to want to help me do the programming after board level installation. Can anybody point me to a system that will allow manual programming of this chip with some type of programming socket type process??
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Kindly refer to the Programming specification
On page 7, Figure 2-1, you will find the minimum required connections for the end product to support ISSP. You can kindly substitute MiniProg for Host System. All that is needed to two power supply pins and two GPIO pins and a reset pin.
You can make a small PCB with the required five connections to MiniProg, as shown in the diagram mentioned earlier. You can even use a ZIF socket in this PCB, which can make it safe and easy to mount and unmount the devices for programming.
You can also use third party device programmers to program CY8C29866-24AXI 100TQFP. You might need to purchase a 100TQFP adapter separately. Kindly follow the column "PSoC1".
Sampath Selvaraj
SampathS_11
Sampath Selvaraj
