filter
feme_285141
Level 4
Level 4
as I convert the value to the filter med (Filter_Read8 ()) to numerical voltage value ??
Bob_Marlowe
Level 10
Level 10
I assume v is calculated correctly, you may check that in debugger.
To print a float:
Set the heap size to 0x200 (.cydwr view -> System tab)
Set Use newlib-nano and Use newlib-nano float formatting both to TRUE (Project -> Build settings -> Linker)
Bob
Bob_Marlowe
Level 10
Level 10
Bob
feme_285141
Level 4
Level 4
 for(;;)
        /* Poll waiting for the holding register to have data to read */
        while (Filter_IsInterruptChannelA() == 0) ;
        num = (Filter_Read8(Filter_CHANNEL_A));
        v = ((num*5.00)/255);//// Problem ??????????????????????????
        sprintf((char *)wrBuffer, "v = %2.f\n\r",v);
        PrintToUSBUART((char8 *)wrBuffer);
        CyDelay(1000);
Bob_Marlowe
Level 10
Level 10
To print a float:
Bob
