Hi guys,
Maybe you can help me.
After including this library in my project on PSoC3, happend such error during the bilding.
In project i have only GraphicLCDIntf_1.
I made all steps discribed in user guide for this library.
But after bilding had:
*** ERROR L127: UNRESOLVED EXTERNAL SYMBOL
SYMBOL: GUI_X_Config
MODULE: ..\LinkLibrary\PSoC3\Keil_PK51\emWinnosnts.lib (GUI_CORE)
Program Size: data=11.0 xdata=1704 const=493 code=3317
The command 'LX51.exe' failed with exit code '2'.
PSoC 3
It looks like you are missing a .h-file in your project. Start a search through all files for the missing external symbol to get a feeling where you missed something.
Bob
Thank you for answer.
But I have such structure like in user guide: http://www.cypress.com/go/comp_emWin
Solution - to add in project:
* GUI_X_Config
void GUI_X_Config(void) {
static U32 aMemory[GUI_NUMBYTES >> 2]; /* Memory block for emWin, 32bit aligned */
GUI_ALLOC_AssignMemory(aMemory, GUI_NUMBYTES & 0xFFFFFFFC); /* Assign it to emWin */
GUI_ALLOC_SetAvBlockSize(GUI_BLOCKSIZE); /* Set average memory block size */
