wmaxfield
Level 4
Level 4
10 replies posted 10 likes received 5 questions asked
A recent post indicated issues with emfile.
During work with a psoc5 in 2017, I found there were some issues with Port 3 when using spi.
The post from 2017 is here:
https://community.infineon.com/t5/PSoC-5-3-1/PSOC5-and-SDCARD-warning/td-p/87769
The emFile component uses a software interrupt when there are errors, which defaults to am ARM vector table which halts the psoc.  So, you can have lockup if a bad sdcard or other emFile using device is inserted.
You will have to purchase a license to get the emFile source to fix this problem, or use the open source options pointed to by others.
Gautami_12
50 likes received 100 solutions authored 250 replies posted
Hi @wmaxfield ,
Thank you for sharing this information in community.
Warm Regards,
Gautami J
Gautami_12
Hi @wmaxfield ,
Warm Regards,
Gautami J
