Padmini
what is the difference between CY8C5868AXI-LP035 and CY8C5888AXI-LP096 ?
Hari
Hi @Padmini
The last 3 do not have any meaning associated with them. Please see the image below from the datasheet. The peripheral set is the same for the two MPNs.
Hari
Hari
Hi @Padmini
The difference between the two chips is the CPU speed. The 5868 has a max CPU speed of 60MHz whereas the 5888 supports CPU speed of 80MHz.
Hari
Padmini
Hi Hari,
Thanks for quick response.
Understood about the CPU speed, what about peripheral set (last 3 digits i.e 035 and 096) difference ?
Padmini
Hari
Hi @Padmini
Hari
