what is the difference between CY8C5868AXI-LP035 and CY8C5888AXI-LP096 ?
PSoC general
Hi @Padmini
The last 3 do not have any meaning associated with them. Please see the image below from the datasheet. The peripheral set is the same for the two MPNs.
Hari
Hi @Padmini
The difference between the two chips is the CPU speed. The 5868 has a max CPU speed of 60MHz whereas the 5888 supports CPU speed of 80MHz.
Hari
Hi Hari,
Thanks for quick response.
Understood about the CPU speed, what about peripheral set (last 3 digits i.e 035 and 096) difference ?
Padmini
Hi @Padmini
Hari
