did burn The Same HEX file to several CY8C24123A-24SXI, but the behavior is different.
kona_777826
Sorry for the non detailed questions.
and
I'm sorry for my bad English.
i did buru same hex file to several CY8C24123A, but can't same behavior.
hardware and power line is stable.(checked with oscilloscope)
very shimple project(like Blink) was moveing at every board.
but attached project is not.
I'm sure that is a rudimentary mistake,
i readed datasheet and TRM.. but I coud't found cause...
Once again
Sorry for the non detailed and rudimentary questions.
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
I have reviewed the project. It is a PID controller taking input from a Delsig ADC, and giving output to motor via PWM. Assuming the hardware on all the boards is perfect, this project should work the same for every board. Else, there may be an issue with the hardware or the test system.
Let us know more about the hardware, and the test system. Please let us know the difference in behaviour.
Sampath Selvaraj
