So I am trying to figure out whether I have just a code size issue or a memory allocation issue or a linker issue. I had a project in 4.4 with csd and ezi2c. I loaded into 5.1. It told me it was going to update boot.ldr and update csd from version 1.0 to 1.5. after it was done I regenerated and compiled and got the following errors
Linking..
LMM info: area 'InterruptRAM' uses 65 bytes in SRAM bank 0
LMM info: area 'ram2' item of 83 bytes allocated in SRAM page 0
LMM info: area 'ram1' item of 80 bytes allocated in SRAM page 0
LMM info: area 'data' item of 26 bytes allocated in SRAM page 0
LMM info: area 'data' item of 2 bytes allocated in SRAM page 0
LMM info: area 'data' item of 1 bytes allocated in SRAM page 1
!E <library>(2569): {linker} Cannot allocate space for 12 bytes for 'bss' area
!E <library>(2569): {linker} Cannot allocate space for 40 bytes for 'bss' area
!E <library>(2569): {linker} Cannot allocate space for paged area 'virtual_registers'
!E <library>(2569): {linker} Cannot allocate space for 1 bytes for 'data' area
!E <library>(2569): {linker} Cannot allocate space for 2 bytes for 'data' area
So is the new csd module bigger and so now it won't fit into my part or do I need to configure the imagecraft compiler or linker some how to make this fit?
Any insight into this would be greatly appreciated.
Ray
PSoC 1
