project is known good and works on a Windows 10 box.
On Windows 8.1 box w/ creator installed I have a driver error no driver loads.
Error Pictured:
On a Windows 10 box (no Cypress Creator/Programmer suite installed), the USB UART driver automatically installed with no problem. It's using the Microsoft USB to Serial driver. Pictured here:
- usb uart
Hello Daniel,
You can download Microsoft Certified USB UART Driver from the link below and try using it on Windows 8.1
https://www.cypress.com/documentation/software-and-drivers/microsoft-certified-usb-uart-driver
Also, please have a look at the thread: Use of the Cypress Microsoft Certified USB UART Driver which mentions that:
"For Windows 8 and Windows 8.1 you cannot use the PID 0003 for the USB-UART example project for PSoC. It will be good if you use the PID as 0008 instead to bind your device".
Best Regards
Ekta
