Hello Cypress team,
We have to store port configuration to EEPROM of cy8c9560a
We have modified all port register and that configuration we are wiring to EEPROM by command register
i have tried both command 1 and 3. both are not working and getting the error like SCL is holding slave more 300ms
commad 6 and 7 are working fine. but all writing commands are not working
we are using CY8C9560A -24AXI part number
Please help us to solve this issue
Nazar
Hello Nazar,
Commands Store Config to E2 POR Defaults Cmd (01h) and Write E2 POR Defaults Cmd (03h) write 147 data bytes to flash. 147 data bytes would be spread over 3 flash blocks. SCL can hold the master for upto 600ms (200ms * 3). Hence, do kindly allow 600ms. If there is any error, the port expander will NACK. Do kindly let me know if the port expander NACKs after 600ms.
Sampath Selvaraj
Hello Nazar,
Sampath Selvaraj
Thanks sampath
Now it is working fine with 600ms timeout
