hi
what is the amount of frequency when we connect clock of one digital block
to another block like DBB11(like block drawed blow)
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
Look at digital block clock frequency specs, its a f() of component type
as well as gate level limitations. In the case of the latter looks like
49.2 Mhz in the case of raw clock chaining frequency on the input
side. But one cannot assume this would be chaining out.
You might want to confirm this by filing a CASE -
To create a technical or issue case at Cypress -
www.cypress.com
“Support”
“Technical Support”
“Create a Case”
You have to be registered on Cypress web site first.
Regards, Dana.
