hello I want to use the UART ,how ever i saw this video
as you can see he used UART(scb) how ever in my PSoc Creator ver 4.1 when i search for the UART(scb) I cant use this block becouse it is incompatible . maeby becouse the verson of the UART(scb) it self is old verson . Is there a new verson of this block ? or maeby other solution ?
In Creator select "Project -> Update Components..." and follow the advices.
Happy coding
Bob
PS: Actual Creator version is 4.2
I tried what u said but it is written possible to update this component
Can you please post your complete project or a shortened version that shows the error so that we all can have a look at all of your settings. To do so, use
Bob
The SCB-UART is not made for PSoC5, use the UART component offered in component window.
Bob
The problem that there is no video to use other kind of UART.
You do not need a video, just use the datasheet which explains configuring the component. Take care for the pins: on your PSoC5 board the USB-UART bridge uses different I/O pins, check the schematic. Which board are you using CY8CKIT-0??
Bob
i am currently using spark fun2 lp-096.
for exmaple there is this video
and I want to use this uart to send data from the psoc to matlab how ever i cant use the same block as he . how to solve this problem?
Bob is correct... the SCB is a hardware block that is only available in the PSoC4 and PSoC6 family.
Alan
