hi everyone, i have this error on both my desktop and laptop. Unable to open the file for reading. Could not find a part of the path 'C:\Users\sebas\OneDrive\Documents\PSoC Creator\4.4\Downloads ( 4.4).cylib\cy_boot_v6_10\PSoC5\API\cm3gcc.ld'.
this is a fresh install with a new project. i did have psoc before but somehow the programmer got lost so i needed to reinstall it. and now i have this error.
i also needed to reinstall windows on my laptop becouse some how psoc installer was not able to install the updatemaneager.
PSoC5 LP MCU
1: Uninstall the PSoC Creator 4.4 in your PC.
2: Download the PSoC Creator install package from the linker:
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.psoccreator
3: It is not recommended to use the "update manager"
4: Which windows version do you use?
sadly it did not work
hi thanks, can I just uninstall it in the control panel or with the update manager?
on my laptop windows Version 10.0.19042 Build 190424
pc is windowns Version 10.0.19044 Build 19044
Has this problem been solved, now?
