Is a baud rate of 115200 only supported via the kitprog FW ? I am using CY8Ckit-059 and wish to use a higher baud rate for an application . like 460800 baud
I tried by changing the baud rate on the UDB in my application and did not get consistent desired results on PC terminal window
Sreedhar
PSoC 5LP
The specification of the USB-UART bridge is described in the "KitProg User Guide" document as follows.
The maximum baud rate is 115200
The "KitProg User Guide" can be downloaded from a KIT web page like following.
CY8CKIT-059 PSoC® 5LP Prototyping Kit With Onboard Programmer and Debugger | Cypress Semiconductor
CY8CKIT-046 PSoC® 4 L-Series Pioneer Kit | Cypress Semiconductor
The "KitProg2 User Guide" has same specification.
The "KitProg2 User Guide" can be downloaded from a KIT web page too.
CY8CKIT-145-40XX PSoC® 4000S CapSense Prototyping Kit | Cypress Semiconductor
There is a dedicated WEB page too.
KitProg2 User Guide | Cypress Semiconductor
Noriaki
