I want to make a SPI salve board to verify the SPI master product. That should be support all four SPI slave mode.
I searched in the website and found the development suite CY8CKIT-002 and chip CY8C20236A-24LKXI can support my requirement. Please help check whether it is right. If right, is that CY8C20236A-24LKXI need to design a demo board to support the validation? Do you have reference design circuit or reference demo board?
Thank you in advance!
To build an SPI slave or master it would be sufficient to use any of the Cypress prototyping kits as the CY8CKIT-043 or -059
You may even use for debugging purposes the built-in USB-UART bridge to display data on your pc screen.
Bob
Bob
Thank you Bob!
Happy new year!
