EnPa_1371286
5 replies posted 5 questions asked First reply posted
Is the XRES output of MiniProg3 configured as push-pull or as open-drain?
Thank you in advance.
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @EnPa_1371286 ,
The XRES output pin on the MinProg3 has a strong drive configuration and there are no pull-ups or pull-downs on the same.
Warm Regards
Alen
AlenAn14
Hi @EnPa_1371286 ,
Thank you for using Inifneon products.
We have forwarded your query to our internal team, who will evaluate your query.
We will provide a response as soon as we get an update from our internal team.
Thank you for your patience.
Warm Regards
Alen
AlenAn14
Hi @EnPa_1371286 ,
Apologies for the delay on this query!
We are still working with the internal team for understanding the configuration of the XRES.
Can you please let me know why you require this information in the mean time?
Warm Regards
Alen
DennisS_46
50 solutions authored 50 sign-ins 100 replies posted
XRES is determine by the chip being programmed. XRES is active high for PSoC1 parts (CY8cC2xxxx), and active low for PSoC4 and PSoC5LP. This is stated in the respective datasheets for the parts.
---- Dennis Seguine
PSoC Applications Engineer
DennisS_46
Clarification:
When XRES is asserted high, there is a pull down to vss when off.
When XRES is asserted low, there is a pull up to vdd when off.
---- Dennis
AlenAn14
Hi @EnPa_1371286 ,
Warm Regards
Alen
