when i create this loop
for(a = 0; a < samples; a++)
sprintf(buffer,"%4.2d\t %6.2ld \n", a,adcCounts);
FS_Write(pFile,buffer,sizeof(buffer));
CyDelay(1);
Build error: ERROR: L107: ADDRESS SPACE OVERFLOW XDATA ?XD?EMFILE_1_CONFIGMMC_SPI 001000H
is it normal to happen?
Romil
PSoC 3
Raise your heap and stack size, double or quadruple them, they were lowered from earlier standard
settings and have caused some problems not being large enough.
The heap and stack size were reduced in 3.1, try restoring to 3.0 levels 4K and 16K respectively.
3.1 default settings are now 128 bytes and 2K.
System tab in xxxxx*.cydwr file, workspace explorer near the top.
Regards, Dana.
i can have this item on system.
check the image
i need to change on psoc 3
Currently can only do images as attachments.
Regards, Dana.
if you see my image you didn't see the heap and stack settings on PSOC3.
how can i set on psoc 3 this settings?
Romil A
My mistake, the memory management is different for 8051 core.
The error thrown looks like a linker error, did you look this up in the Keil Linker docs ?
Google the error, multiple hits, I googled "Build error: ERROR: L107: ADDRESS SPACE OVERFLOW XDATA keil",
saw this -
http://www.keil.com/support/docs/1241.htm
Regards, Dana.
i check this solution and it don't help me because i need to increase the array size.
it is possible to set the stack and heap on psoc3?
regards,
Romil
The 8051 processor has got a 256byte fixed stack. When you want to use malloc() functionalities there is a way for doing that. As far as I remember you find some instructions for that on the ARM / KEIL website.
Bob
