ButchT
First comment on blog First reply posted 5 questions asked
Back on the miniprog3 issue with win 10. This is now becoming a Problem seeing this at MAC also on win 10 boxes. I need a solution..
this is what device manager is telling me:
Searched net, no solutions found here...
Using: Windows 10 configuration.
Ekta_N
750 replies posted First like given 250 solutions authored
Hi @ButchT
Could you please try manually binding the driver to the device:
Try manually binding the device to the driver in FX3 SDK:
1. Right-click on the device in the device manager.
2. Select Update driver -> Browse my computer for driver software ->   Let me pick from a list of available drivers on my computer -> Have Disk -> Browse.
3. Miniprog driver should be located in the following:
C:\Program Files (x86)\Cypress\Programmer\drivers\mprog3..
I am using Windows 10 and I am not able to reproduce the issue at my end. Could you please let me know if you can replicate this issue with any other device?
Are you on a shared network?
Best Regards
Ekta
Ekta_N
Hi @ButchT
Best Regards
Ekta
