Why SPI is giving wierd behavior?
Hello Every one,
I am trying to communicate my PSOC chip 5LP (LP035) with Raspberry Pi.
PSOC is acting as slave and Pi is a Master.
Between the communication I set up a mask that is responsible for giving back the required channel value to the master (Pi).
My code was working properly but now it start behaving different (I have not change any thing!) .
It only works correct when master send a mask value either 1 or 3.
I dont understand where the problem is laying.
I will be very thankful to you If any body can help me in it!
Looking forward to hearing from you!
AnkitaS_51
 Can use "if(!(SPIS_ReadRxStatus() & SPIS_STS_RX_FIFO_NOT_EMPTY))" instead of  "if(SPIS_GetRxBufferSize())"
Thank you ANKS for your reply.
I tried that thing but i am still getting garbage values.
Do i need to slow down the clock?
