Dear Sir/Madam,
I use MiniProg3 with "ppcli.exe" tool to do FW programming.
However, DAP acquire takes very long to fail for the fail units.
Could you advise how I can adjust the timeout to be lower?
Is there a command for "ppcli.exe." to lower the timeout?
Please advise.
PSoC 3
Hi frgr_4179106,
Unfortunately, there is no option to set the timeout for the DAP_Acquire() API.
Can you please let me know the reason why the devices are failing in the acquire process? Also, can you attach the ppcli script?
Thanks and Regards,
Rakshith M B
Rakshith M B
Hi frgr_4179106,
Thanks and Regards,
Rakshith M B
Rakshith M B
