06:14 AM
May 03, 2017
06:14 AM
Hi
I am using Control Register to write data to GPIO. I have to send a array to GPIO continuously. Size of array is 1Kbyte. I want to use DMA for Data Transfer. How do I write control register address to DMA for this?
I also need a DMA interrupt. I need to generate a clock signal after each transfer data of the DMA. If the DMA transfer size is 1024 Bytes, I need 1024 interrupt. Because I need to generate a clock signal after writing data to the GPIO.
How can I do this with DMA?
Thank You
Labels
PSoC 5LP
06:41 AM
May 03, 2017
06:41 AM
06:41 AM
May 03, 2017
06:41 AM
06:44 AM
May 03, 2017
06:44 AM
@odissey1 Thanks
I'm looking at.
