Using DMA in ALU UDB project
Hi.
Just one question. How can I using DMA put data from PSoC SRAM to registers in ALU, for example I want to send uint8 byte to A1 register without using ARM processor - that means without using this code ' component01_<ALU_1>__A1_REG = byte;'.
With regards.
Bob_Marlowe
Level 10
Level 10
IO to datapath components is usually done using the FIFOs This is quite more flexible. The transfer from FIFO to a register is then done using a UDB state machine.
Bob
Then it isn't possible to directly (using DMA) write or read to/from ALU registers? Can you show example, how to configure DMA to write or read from ALU? I've read datasheets, Application Notes, but still can't find answer to this problem.
Bob_Marlowe
Level 10
Level 10
Read "Component Author Guide". Chapter 6.4 gives you the name of the accumulator in your component.
Chapter 7 shows how to implement DMA capabilities.
Bob
