I'm research assistant at the Technical University Darmstadt. I'm responsible for the lecture "Microprocessor Systems". In this lecture we show the students the basics around a microcontroller and also teach them programming assembler with a Cortex M3. Till now we use Keil uVison and the simulator. In the next semester (end of march) we want to give them also some hardware, to give them the opportunity to test there programs on real hardware. I plan to mix C and assembler to make it easy to use the peripherals. The c file with the main function and the peripheral calls and a assembler file where the students write there functions. I read "AN89610", "THE LOST ART OF ASSEMBLY LANGUAGE PROGRAMMING" and "Using variables/functions to and from C and assembly"
What is fine:
I can create a new project declare a extern function and call them like
#include "project.h"
extern void FunctionName();
FunctionName();
for(;;)
/* Place your application code here. */
If I also created a GNUArmAssembly file and uncomment the assembler function like
.global FunctionName
.func FunctionName, FunctionName
.thumb_func
FunctionName:
BX lr
.endfunc
What is not working:
I can't use conditional execution like in Keil uVision like (Error: thumb conditional instruction should be in IT block)
.thumb_func
FunctionName:
CMP R0,#1
ADDLO R0,#1
BX lr
.endfunc
When I create a MDKArmAssembly and uncomment the assembler function like
FunctionName2 FUNCTION
EXPORT FunctionName2
BX lr
ENDFUNC
and a c file like
extern void FunctionName2();
FunctionName();
FunctionName2();
for(;;)
I get the error message "Build error: undefined reference to `FunctionName2'"
(I download the Keil MDK and include it by going to "Tools --> Options... --> Project Management --> ARM Toolchains" and add the path C:\Keil_v5\ARM\ARMCC\bin to "ARM MDK Generic:")
Is it possible to use conditional execution and the gnu compiler without the IT blocks?
Whydo I get the error when I call a function from a MDKArmAssembly file?
Thank you very much for any help or link.
PSoC 5LP
I totally agree with others' opinion about teaching assembler.
Meantime in my FPGA course, I'm not sedulous enough to write a c-compiler
for a 4-bit CPU implemented in a FPGA 😜
Anyway, just for fun I've tried below
main.c
#ifdef __GNUC__
#else
#endif
#ifdef __GNUC__
FunctionName();
#else
FunctionName2();
#endif
for(;;)
MDKArmAssembly01.s
(A space before ENDFUNC was required)
AREA |.text|,CODE
THUMB
BX lr
ENDFUNC
END
I needed to modify/add
Tools > Project Management > ARM Toolchains
Default Toolchain: ARM MDK Generic (or ARM GCC 5.4-...)
ARM MDK Genereic (default)
C:\Keil_v526\ARM\ARMCC\bin
as well as in Project > Build Settings
Select
ToolChain: ARM MDK Generic (or ARM GCC 5.4 ...)
I hope this was what you were asking...
moto
dominik,
there are no jobs for assembler programming, you may reconsider what to teach students.
/odissey1
I've learnt seven different assemblers. When you know one, you know them all. But more than the principles as adressing modes, registers, flags and exception handling is not required. What you need is to follow the generated code when debugging. Writing programs in assembly language is outdated. There are other targets that need to be taught i.e project management or writing a functional definition document.
Bob
main.c
#ifdef __GNUC__
#else
#endif
#ifdef __GNUC__
FunctionName();
#else
FunctionName2();
#endif
for(;;)
MDKArmAssembly01.s
AREA |.text|,CODE
THUMB
BX lr
ENDFUNC
END
Select
moto
thank you very much, it works fine now.
I totally agree with you, but I'm just the Research Assistant and the Prof. want to teach it, so my goal is to make it as practical as I can.
