User NVL Arrays error duribng automated program
I have a problem. When trying to use a script to program a PSOC3 device with MiniProg3 (WinXP) the programming doesn't work. This script comes directly from the cypress website with a few changes.
What is really wrong: If i execute the script, the programming doesn't work on a new device. When programming a device that was previously programmed with PSOC programmer 3.13.3, the script works for some reason... To find out what is wrong, i programmed a new device with the script and then started PSOC3 programmer 3.13.3. I used verify and it verified all 64 flash blocks. Only the "User NVL Array's" are unverified.
Can someone take a look at the script and tell me what is wrong?
Thx!
Can you raise a case with Cypress Tech Support to get your issue resolved.
