Usb driver for android
My problem is that I want to use the module's USB UART Psoc1 24864. But the problem is that I would use android.
do you know if there is a driver for the PSoC on android?
Thank you
pushekm_21
10 likes received 5 likes given First like received
USBUART UM generates the inf file which points to USBSER.sys file (belongs to CDC driver class) for its operation. I seriously doubt about that the USBUART will work with Android OS without any modification. Support for Androird OS needs to be worked out at the Cypress end. I'll report the same.
Pushek
