Community will be in read-only mode on 25th Sep for 10 hours. Click here for more details
adrian_west
We where using a CY8C5888LTI-LP097. We where unable to get those parts.  So,  we got some CY8C5868LTI-LP039 off of ebay.
I am struggling to flash the CY8C5868LTI-LP039. I am using the MiniProgrammer4 with a 10pin header. This was working with our old processer but not the CY8C5868LTI-LP039.
The programmer reports the correct part and is able to erases the flah. But not program the part.
I recompiled the project with the new part and got no errors and got a new hex file.  I have been using the hex file the entire time.
Log from flash program:
Program Finished at 3:24:42 PM |
| FAILED! Unknown error
| Erase Succeeded
| JtagID: 2E 12 70 69
Program Requested at 3:24:40 PM |
Power On at 3:24:31 PM | MiniProg4 (CMSIS-DAP/BULK/110C14D101310400)
Anyone have any ideas as to what my issue could be.
DennisS_46
100 sign-ins 50 likes received 50 solutions authored
Adrian:
You may have bogus parts, ebay is not the most secure source. I just went through this with a customer who bought PSoC3 parts from a broker. It turns out the parts were most probably from a scrapped lot that happened to
"fall off the back of the truck" on the way to the scrap yard. I regret to inform you that, by Infineon official policy, we are not allowed to provide support, including failure analysis, for parts purchased outside of our normal direct or distribution channels. I suggest that you contact your local Infineon sales or distribution representative and procure (beg) a few samples from them to verify that your programming connections and project hex file are indeed correct. The sales guys should be able to find a few samples.
---- Dennis Seguine, PSoC Applications Engineer
DennisS_46
The chip-ID is correct for ..LTI-LP039.
Did you re-build your project using the new chip part number?
---- Dennis Seguine, PSoC applications engineer
adrian_west
Yes I did,  I also used the that hex file and was unable to program the device.
DennisS_46
Adrian:
