If you use RTOS (toppers asp), USB-UART configuration will not be finished.
Specifically,
while (! USBUART - 1 _ GetConfiguration ());
does not satisfy the termination condition
Has anyone implemented CDC with USB-UART with toppers asp?
asp_cy8ckit050_gcc_20140204.zip(SJIS版)
PSoC 5 Device Programming
PSoC 5LP
As far as we know, Cypress has not used Toppers asp.
Since this issue is very specific to a custom RTOS, we are not sure what extent we can support.
Do you have any other problem apart from USBUART_1_GetConfiguration() API while using Toppers asp?
Hirotaka Takayama
Thank you for your response.
I thought that I would get advice if there was a person who chose toppers and used it.
I will try to implement USBUART.
There are no problems other than the USBUART_1_GetConfiguration () API now.
To investigate the root-cause, could you check following 2 things?
Did you confirm that the Usb configuration works without RTOS?
Could you try with only one task (which is for USB) and see if that works?
Hirotaka Takayama
I will attach the project (USB_communications.zip)which I confirmed the operation without RTOS.
It works without problems.
If you try only main task(test.zip), it works as expected.
Is the USBUART stuck because the USB caused interrupt is not registered correctly in the RTOS?
We will continue to investigate.
Sorry for the delay in my response.
In this case, it is problem happens on RTOS (toppers asp).
Since Cypress is not very familiar with toppers asp, our support is limited.
Someone might answer on this thread, but Cypress recommend you to check it with RTOS vendor.
Hirotaka Takayama
