ZvVe_2582751
First like given
I'm using USBUART in PSOC5 with FreeRTOS
In USBUART_episr.c I added the following code:
CY_ISR(USBUART_SOF_ISR)
     /* `#START SOF_USER_CODE` Place your code here */
     if (USBUART_DataIsReady()!=0 && USBUART_GetCount ()!=0)
           //Send semaphore to ReceiveTask
     /* `#END` */
void vReceiveTask( void *pvParameters )
         while (1)
                 USBUART_GetData (...)
From the PC I want to send one message to the serial port that will be received in USBUART.
What is the maximum message I can send ?
Thank you,
Zvika
AnkitaS_51
Message length depends on Endpoint setting .As you can check in this Code example as attached the Bulk endpoint have maximum packet length set as 64.
AnkitaS_51
Hi anks,
Thank you very much for your reply.
Zvika
