Has anybody here been able to do USB audio with using the CY8C58LP family?
I want to get the CY8CKIT-059, to use a test/development platform.
I am looking for something really simple. I want to have USB audio from windows or mac and output standard I2S (24-bit up to 192kHz).
Is this doable?
Thanks;
Leo
Orchard Audio LLC.
ispn:39618:1:0
l1:314:1:0
PSoC5LP
You need to change the MPN to CY8C5888LTI-LP097 in the PSoC Creator Project by going to the Device Selector.
This project will build in older version of creator.
I tried to do this but I get the following error:
The selected device for the Bootloader and Bootloadable projects must match, but don't. Bootloader is targeting 'CY8C5868LTI-LP039' and Bootloadable is targeting 'CY8C5888LTI-LP097'.
When I go to change the bootloader setting, I do not have any options.
First you need to Change MPN for both bootloadable and bootloader project.
Then,after giving build to Bootloader project ,give the path of its .hex and .elf in Bootloadable component Dependencies
Is there something that can walk me though this step by step? I cannot figure out how to do this in the menus.
I am using Creator 3.1 SP3, do I need a different version?
I was able to get the project to compile and program, the issue now is that when I plug the device into a computer noting happens. Should it not be detected as an Audio device in windows?
I have Windows7
When connected, the device is visible in the system and becomes the device and the playback by default.
Unfortunately I do not have 24-bit I2S devices and I do not know how to change the project parameters to 16 bits.
Maybe you will be interested in this:
http://www.cypress.com/forum/psoc-creator-software/simple-usb-audio-template
https://github.com/MichaelTien8901/usbaudio
I got it to work. I am seeing the device in windows, but now I have another quesion.
My only options are upto 48kHz and 24bit, do I need to do something else special to get 96kHz 24bit as well as 192khz and 24bit?
The AudioClkGen component datasheet (page 7) says that it is possible to set 96 kHz,
But I unfortunately do not know how to do it and configure the USB interface.
Maybe you need to ask your questions on the author's page, but there is no activity there for 2 years already.
