chmoc_1567941
Level 4
Level 4
how can i set UART in interrupt service routine????
its like whenever UART receive some value than isr function call.....
HeLi_263931
Level 8
Level 8
You can access the UART from an ISR as you would do in all other places in your code. Nothing special there. But since an ISR is typically time-critical, don't do any longer operations there.
chmoc_1567941
Level 4
Level 4
i tried this many times but i cant do that perfectly.
is that any sample project available on pscoc1?? which can explain me UART in ISR
