Hi, I want to wake up the PSoC when I receive a "1" character in the Rx pin. However when I sleep the PSoC, it don't wake up. How can I do this? Here is my project
Bob_Marlowe
Level 10
Level 10
Sorry, but that will not work as you want. Have a look into AN77900. Table 1 on page 3 lists all the available wakeup sources. There is no general interrupt mentioned, but the PICU (Peripheral Interrupt Controller Unit) which has the ability to wakeup the PSoC using a GPIO pin, but not on a received character.
Bob
How could I wakeup the PSoC with the UART when I receive a data?
Bob_Marlowe
Level 10
Level 10
You may use the Pin's interrupt capability. It will get the PSoC out of sleep, but probably the reception of the first character fails with a parity error.
Bob
I am trying to use the Alternative Active Mode that allow for waking up using interrupt. I have this line when I want to enter in the AltAct mode "CyPmAltAct(PM_ALT_ACT_TIME_NONE,PM_ALT_ACT_SRC_INTERRUPT);" and I clear the interrupt with "UARTBT_GetRxInterruptSource();" but i can´t wake up the PSoC.
