Hi community, it's me again. I have had a very good time working on my project. I am developing an EMG Measuring device. My purpuse is to send  ADC signals through serial port
I am using these modules
ADC SAR --> FILTER --> VDAC --> ADC DELSIG --> UART.
The signal filtered that comes back from the VDAC goes back to the ADC DELSIG. I haven't found a way to transmit directly from the filter to the UART through polling or DMA. I tried through DMA with the following register UART_TXDATA_PTR, but I get some random output in the serial port. Do you have any ideas? I would appreciate it.
Vasanth
Hello ,
Filter_HOLDA_PTR that you have used in the DMA configuration, points to the lower byte of the result register. Please use  Filter_HOLDAH_PTR instead. This points to most significant bits of the filtered result.
In the filter Data Ready signal can be interrupt. This can be used to pass the data to UART if you want to directly pass the interrupt result to UART.
VRS
Vasanth
The project you have attached does not seem to have the filter,VDAC or DMA components. Is this the right project?
VRS
Yes man, sorry, you are right, I will upload the project
Hey,
It is better to have a interrupt driven filter output. In the interrupt handler you can read the filter output value and send it through UART.
Vasanth
Hello ,
VRS
