Hello all,
I am trying to bootload an application using Bootload Host to a PSoC 5LP CY8CKIT-059, but it keeps giving the below error:
I tried to do it with the USB connection through KitProg and tried to connect an FTDI cable directly to the corresponding Rx, Tx ports, and nothing works.
Would really appreciate if you guys help and point out what I am missing.
Thank you in advance,
Kaan
PSoC 5LP
I would suggest you to use the USB-UART bridge in the Kitprog.
Use an UART bootloader with Tx and RX connected to P12_7 and P12_6 on your -059 KIT, these are internally connected to the bridge.
When the Kitprog is connected you will see an (emulated) com-port on your PC. This you may use for bootloading. Care for all the same baud-rate.
Bob
I tried that. Baud rate, security key, everything. I even checked and unchecked all of the Bootloader commands but still no. Weird thing is when I use a third party serial communication tool(Docklight), I can talk with the device...
Kaan
Can you post your complete project (Bootloader and Bootloadable), so that we all can have a look at all of your settings? To do so, use
Bob
Can you please verify if you have programmed the Bootloader project to the PSoC5LP device. If not please program bootloader.hex and then try bootloading.
Hima
