1: My design is getting more complex, and I have a lot of wires that are long and snake around.  I'd like to use something like Net Names in Altium to connect things, rather than having snaky wires.  Can I do that, and if so, how?
2: I have a lookup table that I want to drive from a counter. The counter output is a bus [2:0] and the LUT has three discrete inputs, IN0, IN1, IN2.  How do I connect these?
Bob_Marlowe
Level 10
Level 10
a1:You can right click on a signal and edit name and width.
a2: Connect your 3 LUT signals with a bit longer wires to the bus, then pick wire by wire and again use "edit name and width"
Bob
Bob_Marlowe
Level 10
Level 10
Bob
I see now!  Thanks
So when I attach a wire to a block with a bus input or output, the wire is automatically a bus.
Then when I create wires to connect the bits on the other block they are also bus wires, which causes the error, until I go tell them to be single bits, and which bit to be.
