Hi, I'm trying to use the ActiveX control in C# to create the bridge between the app and programmer. I imported the control and pasted this code in from the document: http://www.cypress.com/?docID=22268
It's giving me a warning about the namespace "USB2IICcom_EXEClass" and saying it cannot be found. Any ideas on why this won't work?
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Diagnostics;
using USB2IIC;
namespace WindowsFormsApplication1
public partial class Form1 : Form
USB2IICcom_EXEClass Bridge;
public Form1()
InitializeComponent();
private void buttonConnect_Click(object sender, EventArgs e)
if (Bridge != null) return; // Bridge is already connected
// Create Bridge Instance
Bridge = new USB2IICcom_EXEClass();
// Connect Events
Bridge.BridgeConnected = OnBridgeConnect;
Bridge.BridgeDisconnected = OnBridgeDisconnect;
// Start USB Communication
Bridge.InitUSB2IIC(Process.GetCurrentProcess().Id);
private void buttonDisconnect_Click(object sender, EventArgs e)
Bridge = null;
GC.GetTotalMemory(true);
private void OnBridgeConnect(string BridgeID, string str)
MessageBox.Show("Connected: " BridgeID);
private void OnBridgeDisconnect(string BridgeID)
MessageBox.Show("Disconnected: " BridgeID);
PSoC 3
