I am working off the TIA example project and I am measuring a photodiode. Its working great and the output voltage on the TIA component changes with light intensity. When I add the comparator component isolated by it self unhooked to anything the TIA component output stays constant. I have it disabled for now but I am unsure whats causing this. I had intended on taking the output of the TIA and using it as an input to the comparator.
PSoC 5LP
I tested by placing an IDAC component in the design and incrementing the IDAC code in the main loop. I could see the TIA output changing. Please find the project attached.
Vasanth
alexander.roscoe,
What are the warning / error messages reported? Normally, the project won't compile if Comparator's terminals are not connected.
/odissey1
