System freezing problem caused by an interrupt
Hi all, attached zip file is my working project.
As you can see in this file, I'm using two push buttons of CY8CKIT-050 PSoC 5LP Development Kit(P6_1, P15_5) to change the strings of LCD module.
The interrupt associated with the button P15_5 works fine(CY_ISR(subSel)), but when I push the button P6_1(CY_ISR(mainSel)), the system freezes.
I cannot understand the reason of this phenomenon because these two switches basically do the same thing.
Thank you in advance.
