maboc_3939291
I'm using a PSOC 5LP097 KitProg: CY8C5868LTI fo my project.
I want to store data on a SD card and I'm using this document to help me :https://www.cypress.com/file/135136/download
I follow all the steps, but when I want  to build the project have got 2 errors:
- prj.M0120:Build error: Cannot find -lemf16nosnlfn
- prj.M0120:Build error: The command 'arm-none-eabi -gcc.exe'failed with exit code '1'.
I don't know from where theses error comes, I sought on internet but nothing.
Pls if you can help me, this is a work for my study's diploma
Cordially
I join you my project
himam_31
It seems you have not downloaded the EmFile Filesystem provided by Segger. The link to download this is documented in EmFile component datasheet. I have downloaded that added dependencies to those folders/files. I'm attaching the modified project.
Note: The project has issues with VDAC component, specific to the application. I hope these errors are straight forward and you will be able to solve those errors.
Please let us know if this helps.
Hima
himam_31
Hima
Thanks for your help, it's working perfectly now.
Thanks you so much.
