Please, can someone describe what to call in __asm volatile(XXXXX); to reset the PSoC5LP CPU?
Many thanks
Viktor
Viktor,
Why aren't you using void CySoftwareReset(void)?
Answer is very simple. I did not know about that nice function in CyLib.
All works now as expected ... OK ... tested.
Many thanks for your valuable help.
Viktor
Hello.
Something to be aware of...,
A s/w reset is not the same as a h/w reset and can leave some h/w in an unknown state. There was quite a discussion on this a few years back.
BiBi,
The function CySoftwareReset(void) just sets a bit in a RESET_CR2 Control register.
Here's the underlying code:
CY_LIB_RESET_CR2_REG |= CY_LIB_RESET_CR2_RESET;
Here's the section in the PSoC5 TRM for this register:
Hi Len.
I agree with what you described for s/w reset.
I was attempting to point out that a s/w reset is not the same as a h/w reset. Some people thought it was.
Bib,
The TRM claims it is a "System Reset". We can only assume it is HW+SW.
