user_4564791
First like given
Hey guys,
I'm an absolute beginner in PSoc and microcontrollers. I have an 18bit-ADC which transfers the output data with at least 30 MHz. I'm wondering if it is possible with the PSoC 5LP to process such a high data signal frequency.
The ADC is the CDI64500 from Comport Data: https://www.comport-data.com/wp-content/uploads/2016/03/CDI64500_datasheet.pdf
I was thinking about using the Shift Register. Can somebody help me on how to setup a test signal with around 30 MHz and how to evaluate the signal-processing on the PSoc?
Thank you very much!
odissey1
Level 9
Level 9
I recommend posting an ADC part number.
