PSoC 5LP
Yes, an unsynced clock will not work for sure.
The shift-register is made using a datapath object which is clocked by the master-clock. Async clocks for shifting will probably fail. I think there should be a hint in the shiftreg datasheet or a warning.
Bob
Matt,
Can you post your complete project or at least a reduced version that shows the error, so that we all can have a look at all of your settings? To do so, use
Bob
Bob
