I was referring to one of the following documents AN93637 - PSoC® 4 Sensorless Field-Oriented Control (FOC) | Cypress Semiconductor
My main doubt is whether the Sensorless FOC applicable to BLDC motors as well? I assume that BLDC motors are different from PMSM motors in terms of Back EMF for the former it is Trapezoidal and for the later it is sinusoidal. Please help.
JobinT_31
25 likes received 10 likes received 5 likes given
Ideally you will never get actual trapezoidal waveform[with proper edge] out of a BLDC.
As the wiring get better the motor become more FOC from BLDC.
For BLDC motors recommended algorithm is to use Back emf method for sensorless [simple algorithm and circuitry as well] approach. The FOC algorithm can probably make the motor run but wouldn't get any FOC specific features.
AN93637 PSoC 4 Sensorless Field-Oriented Control (FOC).zip (PSoC Creator 3.1)
http://www.cypress.com/documentation/application-notes/an93637-psocr-4-sensorless-field-oriented-con...
Here in this zip you can find example for BackEmf method as well.
Jobin GT
JobinT_31
Jobin GT
