https://www.duo.uio.no/bitstream/handle/10852/82665/5/Olav-Bjerke---masteroppgave.pdf .
Seeking help to reproduce this project. Each & every code is there Please help. It's required on an urgent basis. NEED HEX file for PSoc 5LP Prototyping kit.
Hi @shuvra1 ,
I believe that this issue is already being discussed in this thread - <https://community.infineon.com/t5/PSoC-5-3-1/Potentiostat/m-p/367399#M47600..............>. We will continue our discussion in the original thread and I will go ahead and lock this thread.
Thanks and Regards,
Gautami J
Cypress Semiconductor Corporation
An Infineon Technologies Company
There is a hex file in your zipfile :
Potentiostat\Archive\Potentiostat.cywrk.Archive01.zip\Potentiostat\Design01.cydsn\CortexM3\ARM_GCC_541\Debug
Cant you use that one ? Did you manage to contact Olav Bjerke or the university ?
Hi @shuvra1 ,
Thanks and Regards,
Gautami J
