Hi there
I always used ADC Delta sigma. This is my firs time with Sar ADC.
I have attached a simple project where the minus Sar's input is hooked up to Vref/2
From a pot I change the + input volatge between Vssa and Vdda.
I don't know what I am missing but I expect get negative values when V+ - V- is negative and positive values when the diference is positive.
I just got values from 0 couts to 4095 counts when the positive input is from 0v to 3.3v ,in this case.
Please see attached project.
Thank you in advance
Hi Alejandro,
The problem with your code is that ADC_SAR_1_SAR_WRK0_PTR register is not sign extended; the result is always unsigned. You can use ADC_SAR_1_GetResult16(); API inside the ISR which will return a signed result .
VRS
