This is my first time working with any psoc device and I am having some problems trying to making the SPI module work.
Here is the piece of code not working:
SPI_LORA_WriteTxData(outval); 77 where outval = 0x01
while (SPI_LORA_GetRxBufferSize()<1) ;
return(SPI_LORA_ReadRxData() );
Using the oscilloscope I was able to test that "WriteTxData()" is actually writing data in the buffer, but somehow "GetRxBufferSize()" is returning 0 (where it should read '1' at some point, as far as I know), so the while loop does not break.
Although I can not think of a reason why your issue is happening,
I tried the following test with CY8CKIT-059.
I could not observe your problem, so would you test your hardware with similar program?
schematic
SPIM config
pins
main.c
#include "project.h"
#include "stdio.h"
#define STR_LEN 64
char str[STR_LEN+1] ;
void print(char *str)
UART_PutString(str) ;
void cls(void)
print("\033c") ; /* reset */
CyDelay(20) ;
print("\033[2J") ; /* clear screen */
CyDelay(20) ;
void splash(void)
cls() ;
print("5LP SPI Test") ;
snprintf(str, STR_LEN, "(%s %s)\n", __DATE__, __TIME__) ;
print(str) ;
void init_hardware(void)
CyGlobalIntEnable; /* Enable global interrupts. */
UART_Start() ;
splash() ;
SPIM_Start() ;
uint8_t outval = 0x01 ;
uint8_t inval = 0 ;
init_hardware() ;
for(;;)
SPIM_WriteTxData(outval) ;
while(SPIM_GetRxBufferSize() < 1) ;
inval = SPIM_ReadRxData() ;
snprintf(str, STR_LEN, "out: 0x%02X -> in: 0x%02X\n\r", outval, inval) ;
print(str) ;
outval++ ;
inval = 0 ;
CyDelay(1000) ;
Tera Term log
(1) MISO and MOSI were open
Note: I was not expecting the inval has same value with outval.
Probably as I assigned MISO and MOSI to neighbor pins, they may have affected.
(2) So I connected MISO to GND
Note: inval is alwasy 0x00, which is what I expected.
(3) Next I connected MISO to VDD
Note: Don't keep this connection for a long time or add some resistor between VDD and the pin.
moto
schematic
SPIM config
pins
main.c
#include "stdio.h"
#define STR_LEN 64
void cls(void)
CyDelay(20) ;
CyDelay(20) ;
void splash(void)
cls() ;
print(str) ;
UART_Start() ;
splash() ;
SPIM_Start() ;
uint8_t inval = 0 ;
init_hardware() ;
for(;;)
print(str) ;
outval++ ;
inval = 0 ;
CyDelay(1000) ;
Tera Term log
moto
Hi Moto, it was indeed the Rx and Tx buffer size in the lora module.
Thank you so much.
