Hi Bob,
  Yesterday I was unable to send complete project today i make minimal project so please help me out.
Bob_Marlowe
Level 10
Level 10
You opened a new thread again, please reply to your original post.
   while(!(SPIM_ReadStatus() & SPIM_STS_TX_FIFO_EMPTY));
   SPIM_WriteTxData(transmitdata);
   CS_Write(1u); // This will remove CS before transmission is complete
Better use
   SPIM_WriteTxData(transmitdata);    CS_Write(1u); // Transmission complete, remove CS
Bob
Thanks But i use    SPIM_WriteTxData(transmitdata); in read and write so i have to replace all ??
I change it but still nothing is happened not showing  an array
Post your corrected project.
Bob
Hi Bob,
Here is my Corrected Project so please check it out
My fault, something got scewed up in this editor.
Your code (excerpt):
SPIM_WriteTxData(transmitdata); // Write a command byte
   while(!(SPIM_ReadStatus() & SPIM_STS_SPI_DONE)); // Wait until data transmitted *** Try using the DONE flag
   SPIM_WriteTxData(transmitdata);    // *** This is a superfluid write. Deloete that
CS_Write(1u); // Transmission complete, remove CS. *** Look into eeprom datasheet for CS remaining low or not for complete transaction
CyDelay(5);
CS_Write(0u); // Taking CS low for next write
transmitdata=data;
SPIM_WriteTxData(transmitdata);// Write data byte
SPIM_WriteTxData(transmitdata);  // UNUSED EXTRA WRITE
setAddress(address); // Setting the address after sending command and data. Is this correct?
CS_Write(1u); // Transmission is still in progress. Wait for transmission done!
Change the other parts of your program accordingly.
Bob
Still it is not working check it sir i change it according to you
What is the part number of the eeprom you use? Link to datasheet, please.
What hardware do you use, self-made? Cypress Kit?? Which one (Part number)
Bob
Try this concept...
Bob
Hi Bob,
  As per instruction i run partially spi flash but still i am not getting proper array.
HIII, Shall i get code for SCB mode SPI
