Hi Bob,
Yesterday I was unable to send complete project today i make minimal project so please help me out.
PSoC 5LP
You opened a new thread again, please reply to your original post.
while(!(SPIM_ReadStatus() & SPIM_STS_TX_FIFO_EMPTY));
SPIM_WriteTxData(transmitdata);
CS_Write(1u); // This will remove CS before transmission is complete
Better use
SPIM_WriteTxData(transmitdata); CS_Write(1u); // Transmission complete, remove CS
Bob
Thanks But i use SPIM_WriteTxData(transmitdata); in read and write so i have to replace all ??
I change it but still nothing is happened not showing an array
Post your corrected project.
Bob
My fault, something got scewed up in this editor.
Your code (excerpt):
SPIM_WriteTxData(transmitdata); // Write a command byte
while(!(SPIM_ReadStatus() & SPIM_STS_SPI_DONE)); // Wait until data transmitted *** Try using the DONE flag
SPIM_WriteTxData(transmitdata); // *** This is a superfluid write. Deloete that
CS_Write(1u); // Transmission complete, remove CS. *** Look into eeprom datasheet for CS remaining low or not for complete transaction
CyDelay(5);
CS_Write(0u); // Taking CS low for next write
transmitdata=data;
SPIM_WriteTxData(transmitdata);// Write data byte
SPIM_WriteTxData(transmitdata); // UNUSED EXTRA WRITE
setAddress(address); // Setting the address after sending command and data. Is this correct?
CS_Write(1u); // Transmission is still in progress. Wait for transmission done!
Change the other parts of your program accordingly.
Bob
What is the part number of the eeprom you use? Link to datasheet, please.
What hardware do you use, self-made? Cypress Kit?? Which one (Part number)
Bob
HIII, Shall i get code for SCB mode SPI
