Can we use other components IBIS Model into PSoC5LP IBIS. Let's say PSoC5 is having it's own MUX I have IBS Model of other MUX
PSoC5 LP MCU
- Alan Hawsee
- Todd Dust
Hi Prateek,
What did you mean by incorporate it into PSoC Programming ? Are you thinking that you can use use external spice models in PSoC Creator ? If I understood that correctly, first of all Creator is not a simulating software. Its an IDE with graphical user interface for schematic and other peripheral features. The schematic helps the user to interconnect the components( which are made for the peripherals inside the device) to achieve the functionality. This makes the design process faster and easier. But you can connect components based on the hardware resources available on the device only. You can make your own components if needed( which makes use of the hardware resource/ CPU indirectly). But anything that is not present in the silicon is not possible.
Vasanth R S
Could you please elaborate your request ? What exactly is your requirement ? Are you planning to modify the IBIS model of PSoC5 ? Or are you connecting an external mux and connecting it with PSoC5 IBIS model for you analysis ?
Vasanth
Hi Prateek,
Vasanth R S
